TwinTurbo.NET: Nissan 300ZX forum - Re: How acurate is our knock sensor?
Gho32
on February 15, 2008 at 11:37 AM
posted by Jason300zxTT
on February 14, 2008 at 03:17 PM
the knock sensor is ignored by the ECU at higher rpms, I ended up building a cheap amplifier from a kit so I could listen to the knock sensor while tuning on the road.
Jason300zxTT
15:17:12 02/14/08
I looked at your profile so I'm going to assume you are
Spongerider :)
16:01:05 02/14/08
Sorry need to update my profile.
Jason300zxTT
16:47:42 02/14/08
A EBC will eliminate the use of the detonation sensor
Spongerider :)
18:01:38 02/14/08
that's true, but the computer still pulls the timing
spyhunterTT(nj)
18:05:28 02/14/08
Not if you add in a relay. Coil of the relay should be
MixManMash
12:25:43 02/15/08
Your profiles indicates boosts jets and that your are
Gordo 93TT Daytona
16:36:16 02/14/08
The knock sensor will tell you nothing
lazer(AK)
18:19:30 02/14/08
An SAFC-II can display the knock signal for you in a graph.
apudapus
18:23:46 02/14/08
Re: How acurate is our knock sensor? -
Gho32
11:37:52 02/15/08
