TwinTurbo.NET: Nissan 300ZX forum - Re: help on wheel size - anyone has 9.5" on all 4 corners?
twin3037
on February 08, 2008 at 1:21 PM
posted by zyoulater
on February 07, 2008 at 09:19 PM
My car currently has 18x9.5 +25mm offset ssr gt3's with 265's all the way around and only slight rubbing on the front under full lock turning but not under cornering
zyoulater
21:19:35 02/07/08
depends on offset (n/m)
Guapo
21:20:33 02/07/08
offset is 40 for all, would the rear look skinny? tires are
zyoulater
21:25:12 02/07/08
rear wouldn't look skinny, but you will probably need
Guapo
21:30:52 02/07/08
thanks. Any gains on performance why you have that setup
zyoulater
21:37:14 02/07/08
That is my track setup with R compound tires.
Guapo
21:40:59 02/07/08
Baller.. (n/m)
Turnerscasa (Dallas)
05:26:20 02/08/08
I guess that's where all the money you saved on
ZEngineer
12:19:28 02/08/08
As it should be.
BradZ (FL)
12:25:00 02/08/08
Word...
BradZ (FL)
23:50:32 02/07/08
94redZee
21:22:37 02/07/08
Only the rears
Insomniac (VA)
01:37:59 02/08/08
Many years ago
kuah@splparts.com
12:08:22 02/08/08
i had 18x9 on all 4's on my na afew years back. HP Racing
pearlyellowtt
08:00:44 02/08/08
I used to run 17x9.5 +36 OZ Monte Carlos
sfarrah
09:44:02 02/08/08
What diameter?
Scotts94z32
09:51:13 02/08/08
I have run 9.5 on all 4 corners...more
Mike(La Canada)
10:40:44 02/08/08
275/30/18 ? ? ? (n/m)
Scotts94z32
13:22:19 02/08/08
275/35/18-on the +40's...255/35's on the +22's (n/m)
Mike(La Canada)
23:28:49 02/08/08
I do. 17x9.5 front 18x9.5 rear -Use for both track & DD
Hawkin"Z"
10:48:21 02/08/08
Sweet. What's the offset on the front? (n/m)
BradZ (FL)
12:25:39 02/08/08
38mm in the front :-) (n/m)
Hawkin"Z"
13:25:21 02/08/08
Offset ownz you!
Scotts94z32
13:21:06 02/08/08
Rears, yes. Fronts, no...but I tested the 275's and they fit
Hawkin"Z"
13:32:27 02/08/08
All good over here!
Scotts94z32
16:11:31 02/08/08
Re: help on wheel size - anyone has 9.5" on all 4 corners? -
twin3037
13:21:19 02/08/08
Pic?
Scotts94z32
13:24:09 02/08/08
Re: Pic?
twin3037
13:51:23 02/08/08
Thanks. Hard to tell by that pic though....
Scotts94z32
16:08:06 02/08/08
Re: Thanks. Hard to tell by that pic though....
twin3037
19:39:49 02/08/08
jickel180
13:37:55 02/08/08
