TwinTurbo.NET: Nissan 300ZX forum - give us a call for any technical questions
Seb (specialty-Z)
on November 22, 2007 at 1:13 AM
will do, but I have a little more homework to do
posted by ZEngineer
on November 21, 2007 at 09:17 PM
and enlightenment :)
Click To Go To Our Site
where does the 11:1 A/F ratio rule of thumb come from?
ZEngineer
13:56:49 11/21/07
I don't know the answer to this
awesom-o
14:06:00 11/21/07
It is a built-in safety margin. If you're using a tailpipe
Guapo
14:11:40 11/21/07
understood, thanks. Just a little FYI
ZEngineer
14:18:12 11/21/07
Follow up question -
awesom-o
14:21:19 11/21/07
Guapo's message sums it up nicely
ZEngineer
14:30:38 11/21/07
Odd that you'd have to correct so much. BTW, usually
Guapo
14:34:40 11/21/07
a possible explanation might be
ZEngineer
14:40:05 11/21/07
Hey George, what dual pop intake do you have?
Ash's Z
16:00:31 11/21/07
That's impossible. Our intake doesn't have an imbalance.
ni[X]it
16:58:54 11/21/07
:) (n/m)
Ash's Z
21:43:29 11/21/07
I'm using the JWT replica elbows that used to be available
ZEngineer
17:03:23 11/21/07
I put together a post which made it to FAQ called "The
Ash's Z
21:45:19 11/21/07
duly noted, I'll have to find some sort of hand-held pump
ZEngineer
21:48:29 11/21/07
the accuracy is still bad...
ni[X]it
16:42:45 11/21/07
all the more reason to get a wideband in soon :) (n/m)
ZEngineer
17:04:21 11/21/07
contact me for all the Innovate stuff (n/m)
Seb (specialty-Z)
20:58:16 11/21/07
ZEngineer
21:17:58 11/21/07
give us a call for any technical questions -
Seb (specialty-Z)
01:13:44 11/22/07
When converting from metric to US units that is 11.5:1....
RSR
14:21:32 11/21/07
Mostly to do with combustion temperatures. If you try
Ash's Z
15:14:40 11/21/07
Exactly, it's primarily for cooling.
ZCulture
10:09:20 11/22/07
Google says ...
NytWolf
15:22:32 11/21/07
11.5 is safe, nothing over 12 if you run big turbo/boost
timz
15:23:03 11/21/07
"I've never heard her ping"
AZHeat
15:53:31 11/21/07
where are you getting 11.6 from? (n/m)
Devi13
20:38:40 11/21/07
wideband reading (n/m)
AZHeat
00:23:45 11/22/07
yeah on what octane?
Seb (specialty-Z)
20:59:15 11/21/07
Re: yeah on what octane?
AZHeat
00:23:20 11/22/07
Re: Re: yeah on what octane?
Seb (specialty-Z)
01:12:47 11/22/07
I'm running 19psi on sport 500 with 91 octane for over 1yr.
Devi13
02:52:21 11/22/07
I know what pinging sounds like. I have heard pinging
AZHeat
09:19:28 11/22/07
jas0n3485
10:03:09 11/22/07
check primary timing map
Devi13
13:46:48 11/22/07
sounds like you've got your timing maps
Seb (specialty-Z)
16:33:21 11/22/07
Re: I'm running 19psi on sport 500 with 91 octane for over 1
Seb (specialty-Z)
16:32:28 11/22/07
Actually its very advanced.
Devi13
03:07:52 11/23/07
Re: Actually its very advanced.
Seb (specialty-Z)
13:48:17 11/23/07
intercooler setup
Devi13
14:22:24 11/23/07
