TwinTurbo.NET: Nissan 300ZX forum - The oil hole in the lifter is more for lifter bleed down
aliaZ
on November 02, 2007 at 2:49 PM
Probably the 350Z engine has been engineered to allow oiling
posted by LitlElvis
on November 02, 2007 at 02:20 PM
than for cam lobe lubrication, and contributes to a problem of too much oil accumulating under the valve covers. Solid lifters would be an ideal way of eliminating the excess oil in the cylinder heads.
What are the downfalls if any of running solid lifters?
550HPTT
13:22:41 11/02/07
According to Kyle they can go 60k+ before needing adjustment
Eric(NJ)
13:34:05 11/02/07
Kyle also said you need to have the right cams
na300zx (OH)
13:51:48 11/02/07
I will have after market cams, Im looking to have some
550HPTT
13:55:36 11/02/07
A cam grinder told me that you can run
AZHeat
14:00:07 11/02/07
No oil hole to lube the cam lobe...
LitlElvis
13:47:04 11/02/07
Actually you will have more than enough oil. Because
AZHeat
13:53:37 11/02/07
LitlElvis
14:20:53 11/02/07
The oil hole in the lifter is more for lifter bleed down -
aliaZ
14:49:56 11/02/07
Yup. (n/m)
AZHeat
15:46:02 11/02/07
good info. didn't know that. (n/m)
spotz
16:11:58 11/02/07
