TwinTurbo.NET: Nissan 300ZX forum - Give it a shot, just shove a block under the rear tires
Subject Give it a shot, just shove a block under the rear tires
Posted by TriniTT on October 01, 2007 at 12:47 AM
  This message has been viewed 45 times.
In Reply To Moving an engine-less Z posted by ZXRider(SoCal) on October 01, 2007 at 12:06 AM
Message Then, when you're ready to move it back in, try it with the guys you have. If you can't get it to budge, at least it's not rolling back anymore since you have a wedge under the tire. Then just call a couple more guys until you have enough to move it back in. With the motor/tranny out, it's not going to weigh more than ~3k lbs, if you have enough air in the tires then a handful of guys should have no trouble getting it back in.
Two guys moved my tt with the motor/tranny out up an incline, but we had a bit of a flat start to gain momentum, and the incline wasn't as steep as yours. At any rate, you're never completely screwed until you're the last person on earth. Good luck!
Cheers,
JBrobst
