TwinTurbo.NET: Nissan 300ZX forum - For a fixed driveshaft rpm, the rpm of the axles goes down
Subject For a fixed driveshaft rpm, the rpm of the axles goes down
Posted by 300zx90 (CO) on August 23, 2007 at 10:22 AM
  This message has been viewed 166 times.
In Reply To Re: indeed posted by GPA on August 23, 2007 at 10:00 AM
Message If you're looking at diff gears you need to look at the affect on both torque and the rate of work downstream from the gears, not upstream. Hold the input torque and rpm constant and examine the effect of gearing on output torque and rpm. The product of the output is the same as the product of the input minus the losses in the gearbox.
________________________________________
NA to TT, starting from the ground up...
Snow... the new anti-Z. TT.net tested and proven to remove even the most stubborn Z-related posts.
