TwinTurbo.NET: Nissan 300ZX forum - Could be over drawing the charging system w. those fans. (n/m)
YugoBernie (NoVA)
on August 13, 2007 at 11:59 AM
Re: Don't have specific info on that but you should def. install
posted by bajan
on August 13, 2007 at 11:49 AM
Taurus e-fan
bajan
10:59:29 08/13/07
I have no problem with the stock fan (n/m)
Adam (NoVA)
11:08:09 08/13/07
YugoBernie (NoVA)
11:08:13 08/13/07
bajan
11:49:25 08/13/07
Could be over drawing the charging system w. those fans. (n/m) -
YugoBernie (NoVA)
11:59:05 08/13/07
Re: Could be over drawing the charging system w. those fans.
bajan
12:13:15 08/13/07
Yes a 130 amp Alt would help
550HPTT
15:20:56 08/13/07
did you use an in-line fuse? (n/m)
AZHeat
12:17:30 08/13/07
Re: did you use an in-line fuse?
bajan
12:19:02 08/13/07
bajan
11:53:02 08/13/07
Did you install the HI pulley or just the electric fan? (n/m)
12:00:48 08/13/07
Re: Did you install the HI pulley or just the electric fan?
bajan
12:11:32 08/13/07
A loose or corroded connection would cause exactly that (n/m)
550HPTT
12:13:51 08/13/07
a loose connector wouldnt fry a wire i believe
ricerocketeer31
18:46:36 08/13/07
You stand corrected
550HPTT
18:50:30 08/13/07
Are you running a fan controller like
AZHeat
12:11:36 08/13/07
Re: Are you running a fan controller like
bajan
12:18:17 08/13/07
Those fans take about 60 to 70amps to start up
AZHeat
12:24:15 08/13/07
