TwinTurbo.NET: Nissan 300ZX forum - I did the UR pulley, light weight flywheel, and the
zeddiea27
on August 09, 2007 at 8:10 PM
Quick question. Any noticeable gains or advantages
posted by ShakaShaun(Denver)
on August 09, 2007 at 05:58 PM
1 piece driveshaft all at the same time. Didn't notice a difference.
ShakaShaun(Denver)
17:58:40 08/09/07
My 1pc felt alot smoother than stock
TTFairladyZ
18:04:56 08/09/07
2nd... smoooooooth.. (n/m)
z_samurai
18:25:27 08/09/07
Why do you recommend a stock mount over nismo etc. ? (n/m)
550HPTT
18:51:18 08/09/07
The Nismo trans mount isn't rated for the weight of the Z32
YugoBernie (NoVA)
19:44:27 08/09/07
curious; any empirical evidence nismo isn't strong enough? (n/m)
BruPo
23:24:33 08/09/07
Yes - in spite of it "fitting" Nisan only lists it as a
YugoBernie (NoVA)
00:02:04 08/10/07
it doesn't look like it has half the rubber from this post.
BruPo
00:08:35 08/10/07
The amount of rubber is significantly less on the Nismo unit (n/m)
YugoBernie (NoVA)
01:11:48 08/10/07
no dis - i only ask cause my tranny is out right now
BruPo
00:18:07 08/10/07
Good for you. (n/m)
YugoBernie (NoVA)
01:12:28 08/10/07
apparently i've stumbled upon a clash of titans here..
BruPo
11:01:12 08/10/07
pressing on the stock mount with my hand I was
mscurfield
00:33:13 08/10/07
sounds scientific to me (n/m)
Adam (NoVA)
07:32:32 08/10/07
Read this post please
TTFairladyZ
07:07:22 08/10/07
Especially Kyle's responses at the very bottom (n/m)
pallen
09:07:36 08/10/07
Lol, and I swapped mine out after reading on here that
550HPTT
20:09:46 08/09/07
I did the UR pulley, light weight flywheel, and the -
zeddiea27
20:10:06 08/09/07
Hunh? You didn't notice the rpms coming up a lot faster?
CRAZZEPETE.
07:58:29 08/10/07
Agreed...he's full of soft brownies. (n/m)
Fuzznutz
12:45:24 08/10/07
WTF? LOL! I almost spit my food out! (n/m)
zeddiea27
23:15:13 08/10/07
No, not really. I was expecting a huge difference, but
zeddiea27
23:19:19 08/10/07
Check the bracket for your shifter that bolts to the top
Zownr4life
20:29:21 08/09/07
less rotating mass ..try lifting both back to back .. the
The Devils Z
20:37:41 08/09/07
The DS has very little moment of inertia
ZCulture
23:38:56 08/09/07
ok, just ignore all the real tests and data available, not
CRAZZEPETE.
08:10:43 08/10/07
Depends on the shaft
pallen
09:11:41 08/10/07
unless your stock DS is in need of replacement
aliaZ
20:57:54 08/09/07
Thanks for the advise. I didn't think there would be any
ShakaShaun(Denver)
21:53:17 08/09/07
2nd, only consider replacing if CSB goes (n/m)
TTFairladyZ
22:28:00 08/09/07
you might have some intall probs, or balance issues
CRAZZEPETE.
08:12:24 08/10/07
