TwinTurbo.NET: Nissan 300ZX forum - Oil pan uses liquid gasket
Broke_as_****
on July 16, 2007 at 1:47 AM
Main things to replace with TT engine out
posted by Zlover4EVER
on July 15, 2007 at 09:04 PM
The coolant line bypass cleans up the plenum nicely. Timing belt and related items perhaps if it's getting close to changing time. Beyond that and the posts above its mostly repair as needed only.
Zlover4EVER
21:04:44 07/15/07
2x seal-oil camsha: 01001-00191 (n/m)
z32hp*700*
21:12:31 07/15/07
Motor mounts and steering rack bushings (n/m)
EricTTZ
21:26:44 07/15/07
High pressure power steering hose (n/m)
TTFairladyZ
21:34:40 07/15/07
Relocating the pcv system(if you plan on tracking it). (n/m)
Agner.S(CT)
23:00:03 07/15/07
Oil pan uses liquid gasket -
Broke_as_****
01:47:51 07/16/07
Check steering u-joint for play. Easy to get to with motor >
my91z
05:37:41 07/16/07
