TwinTurbo.NET: Nissan 300ZX forum - Main things to replace with TT engine out
Subject Main things to replace with TT engine out
Posted by Zlover4EVER on July 15, 2007 at 9:04 PM
  This message has been viewed 106 times.
Message Hey guys,
I have my motor and trans out to fix a valve cover gasket leak and replace my knock sensor for code 34. I'm also planning on eliminating the egr with the 300degree kit. I'll be replacing both valve cover gaskets btw.
Obviously there are hundreds of things to replace if i could, but what are the MAIN gaskets/seals i should replace. Or anything else you could think of. My turbos are in good shape, are there any important gaskets to change regarding the turbos? Also, does the oil pan get sealed using a gasket or Liquid gasket?
Thanks
Thanks
------------------------------- Sig begins --------------------
In 'n Out before the turbo timer runs out is my benchmark, including foreplay & cuddling! What they're left lacking in the satisfaction dept, is more than made up for in productivity. =) - ZEngineer 14:59:34 04/27/07
Z1 is the best, ive ordered so many parts from them and im always satisfied. they are always there to give advice especially john. they are so much better then AMZnon-performance! - Stsgracing
