| are leaks in the intake piping after the turbo, the turbo has to work harder to supply air to the engine at a given pressure if there are leaks after the compressor discharge. You wouldn't notice all the black soot coming out the tailpipe, but in a worse-case scenario, you would be spinning the bejeezus out of your turbos. Bottom line: routinely inspect your vehicle for problems; 6 P's rings to mind. ;-)
[ ashspecz.com ] [ agpowers@bellsouth.net ] Enthusiasts soon understand each other. --W. Irving. Are you an enthusiast? If you are out to describe the truth, leave elegance to the tailor. Albert Einstein
