TwinTurbo.NET: Nissan 300ZX forum - What happens when you push the clutch pedal down?
Subject What happens when you push the clutch pedal down?
Posted by EricTTZ on May 25, 2007 at 12:22 AM
  This message has been viewed 110 times.
In Reply To so i had a tech meet at my house posted by ARA300ZX on May 25, 2007 at 12:01 AM
Message There isnt much to go off from what you're posting but I'll try....
Has the pedal pressure changed? Is there a leak?
Hows the rod adjustment? If its adjusted too much one way or the other the clutch wont work.
When you're under the car does the clutch fork move?
I would work to try and figure out if something is mechanically broken in the trans like the pivot ball or fork or if there is a leak from the hard line, junction block, slave, master, ss line, banjo, or any connections and then bleed it til there the air is completely gone. Lastly make sure the pedal height is adjusted the right way.
Good luck
Get Labree
AIM: EricTTZ
