TwinTurbo.NET: Nissan 300ZX forum - I've had no problems with my switch but it does occur
Subject I've had no problems with my switch but it does occur
Posted by doug8867 on April 10, 2007 at 12:25 PM
  This message has been viewed 45 times.
In Reply To diffenential oil leak posted by sawbonez on April 10, 2007 at 09:33 AM
Message sometimes from what I've read. Apparently synthetic molecules are more
uniform and are smaller so are able to go where dino oil can't, plus
sometimes detergents in the syn. remove the dino oil build up that formed
around the seal, and this causes a leak. However, the leaks can also seal
themselves after a bit as the synthetic can make the seal more pliable once
it has been "cleaned" and then it seals again. If you're having a leak
problem you could give it a couple months and see if it resolves itself.
Otherwise, you could always try switching back to regular oil and see if it
clears up your problem after a few hundred miles.
