TwinTurbo.NET: Nissan 300ZX forum - Engine Heater = Block Heater.
Subject Engine Heater = Block Heater.
Posted by MixManMash on February 05, 2007 at 3:42 PM
  This message has been viewed 122 times.
In Reply To An engine heater, what exactly is that? posted by 300ZMang on February 05, 2007 at 12:11 PM
Message Block heaters heat up the engine coolant which in turn keeps your engine warmer than ambient. No, it's not going to keep it at operating temperature.
The block heater is operated by your standard wall outlet (i.e. 115 - 120 V AC in North America). You "plug-in" your vehicle in cold temperatures to keep the block warm. Plus, in extreme cold, you need to make sure that your water / coolant mix is good to -40 deg. C. I have seen cases where people have not plugged in their vehicles and the water / coolant mix is not good to -40 deg. C. Guess what happens? Water turns to Ice which expands and the block cracks.
