TwinTurbo.NET: Nissan 300ZX forum - Engine fix is moving in a good direction (sounds like
SirpriZ
on January 06, 2007 at 2:04 PM
Hi Mark!
posted by aliaZ
on January 06, 2007 at 02:00 PM
a politician). The check was rubber so I don't see how you cashed it. I planned to give you a Holiday shout, so this is your Christmas card. Take care, and be talking to you, Mark
Curious about 9.0:1 compression in a TT engine.
WAGGZ
22:37:38 01/05/07
One member already has higher compression pistons but i cant
NobleZ
23:00:38 01/05/07
Carl M.(racerZX) has NA pistons I believe.
WAGGZ
23:08:22 01/05/07
I believe member Scotts94z32 has 9:1 compression
octavian-z
23:10:30 01/05/07
he has the 675 turbos (n/m)
octavian-z
23:20:47 01/05/07
just turbo an NA engine and be done with it :)
vorpalZ
23:08:04 01/05/07
too high
WAGGZ
23:15:56 01/05/07
true, smaller turbos would work better
vorpalZ
23:32:11 01/05/07
the NA engine can't hold boost too well
WAGGZ
23:42:12 01/05/07
wasn't going to boost to his levels
vorpalZ
23:45:37 01/05/07
I believe he only went to 14psi.
WAGGZ
23:49:58 01/05/07
currently have *no* turbos for the 'vert
vorpalZ
00:05:40 01/06/07
Woody75(denver) is the member that has 9.2:1 compression
NobleZ
23:14:01 01/05/07
Member Aliaz has them as well.
Woody75 (Denver)
23:49:32 01/05/07
I'm at 3760 fasl and you are what....5800?
WAGGZ
23:54:18 01/05/07
I knew I wasn't going crazy! I was going to mention Aliaz
Agner.S(CT)
00:37:50 01/06/07
I've got the Endyns as well, just not installed.
ni[X]it
08:06:17 01/06/07
Scotts94z32 sounds like something you need to look
EricTTZ
23:49:34 01/05/07
I ran into detonation issues at different loads going to
SirpriZ
02:55:49 01/06/07
What rpm in 3rd do you get full boost or 1 bar? (n/m)
AzHeat
10:30:21 01/06/07
Manifold starts to see positive pressure around 3,000
SirpriZ
14:00:48 01/06/07
well
aliaZ
11:14:13 01/06/07
Hi Don. Good point. I guess it's hard to factor that out
SirpriZ
13:53:38 01/06/07
Hi Mark!
aliaZ
14:00:11 01/06/07
Engine fix is moving in a good direction (sounds like -
SirpriZ
14:04:24 01/06/07
Have you talked with Mike Smith about this?
Woody75 (Denver)
12:24:39 01/06/07
We're saying the same thing...I put it poorly. Increased
SirpriZ
13:52:08 01/06/07
Actually, I think you did mean that higher compression
SirpriZ
14:13:23 01/06/07
Yes, I'm saying the sources disagree.
Woody75 (Denver)
16:02:51 01/06/07
My source is better than your source! And yes, good
SirpriZ
17:33:56 01/06/07
So... higher compression = more lag, right? (n/m)
WAGGZ
17:20:54 01/06/07
Yes, but.....
SirpriZ
17:56:53 01/06/07
Don't believe everything you read on the internet. (n/m)
ni[X]it
09:28:40 01/07/07
What octane fuel in your state? (n/m)
SirpriZ
18:01:55 01/06/07
91, BUT I have already planned to use a mixture of race
WAGGZ
18:56:55 01/06/07
I don't think you'll be disappointed by the bump
SirpriZ
20:14:48 01/06/07
