TwinTurbo.NET: Nissan 300ZX forum - Potential Transmission Issue for HIGH RWHP Zs ???
Subject Potential Transmission Issue for HIGH RWHP Zs ???
Posted by The Devils Z on December 29, 2006 at 12:27 AM
  This message has been viewed 513 times.
Message A couple of years ago my transmission to a crap. I chalked it up to sloppy driving skills and high rwhp and purchased a brand new 97 plus spec tranny from Nissan.
Well for the past month, I have noticed a wine in the tranny that exists when in neutral that has been getting progressively louder. When I push in the clutch, sounds goes away. There is no noise in the transmission while shiifting, no issues with gears or synchros at all either. Replaced the pivot bearing ( I think that is the one by the oil pan and flywheel ) when I put a new clutch in the car 3-4 months ago.
From talking with a few people, it sounds like my input shaft bearing or the countershaft bearing may need to be replaced. I have not drag raced this tranny, speed shifted, missed any shifts, or grinded any gears. I have "babied it" so to speak with dyno pulls and occassional street pulls.
I wonder if the Z tranny will wear the bearings faster than normal when heavily modded.
My plans to avoid a total tranny failure is to take the input shaft bearing and countershaft bearing ( and maybe the rear input shaft and rear countershaft bearings ) and get them cryo treated. I understand that this cost is pretty cheap and will make the bearings more durable. The center input shaft and center countershaft bearings (I am hoping) should be ok since they are normally pretty well lubricated. If this is so, it should save me $$$ on the labor expense.
Anyway, I am glad that I looked at this while the tranny was down to fix my annoying SGP oil leak ( issue resolved ).
I am not sure what is going on here or if it is user error as well. Figured I'd share. There are a lot of Z's doing major build and this maybe the newest weak link.
And I used MT90 for tranny fluid.
=============Sig begins here================
The Devils Z.com
"....Thanks captain obvious, would you recommend air to resolve a low tire pressure situation? coolant to keep temps down? perhaps a battery for electrical devices? " ... LJZTT on June 10, 2006 at 6:36 PM
"How the hell would you have gotten on the track had you not *somehow* purchased a ticket? He's so overzealous about making other people look bad, that he sticks both feet down his throat. It's fun to watch though :) " ....ZEngineer on June 07, 2006 at 6:22 PM
"as useless as an EGT Gauge..." *shakes head* Its comments
like this that hold the Z32 community back. " ....Z-Jay (Edmonton, AB) on April 21, 2006 at 11:46 AM
"Somebody give this man a medal. Arguing with kenny is like being in the special olympics" ....ENVYMYZ on November 01, 2005 at 11:59 PM
" .. going back and forth with you on a stupid point is like watching a retarded kid double dribble in basketball, you get tired of calling foul all day" ... Slowninja(GT28RS Inconel Z) on October 03, 2005 at 8:43 AM
"the only chips you know about are Doritos. =)" ...ZEngineer on June 11, 2005 at 4:23 PM
"....These posts only serve to make you look even worse, its gotten so bad it even makes me look bad to reply to you...." maglito on January 22, 2005 at 3:11 AM
"What, are you afraid that only a couple of good ones have rolled off the production lines and the rest are crap?? ... Its mechanics not the stockmarket." ... ZisLuv on May 03, 2004 at 6:12 PM
Z32 Power.Com
Dyno
The Devils Z
The Demon Z (in progress)
View Me!
Disclaimer : Not Safe For Work !
