TwinTurbo.NET: Nissan 300ZX forum - No, a leakdown test, leak down test, cylinder leakage test >
Subject No, a leakdown test, leak down test, cylinder leakage test >
Posted by my91z on November 20, 2006 at 2:08 PM
  This message has been viewed 119 times.
In Reply To I think you mean a vacuum test, right? posted by Spongerider :) on November 20, 2006 at 01:26 PM
Message You pressurize the cylinder to a high pressure (80-100psi)and use a gauge to read how much pressure is lost out of the cylinder to get an indication of the health of the engine. Much more informative than a compression test.
That link you show if for a leakdown test, but it is a very lousy one. She doesn't even give you acceptable ranges for results, etc.
Typically, 5-10% leakage is good, and what you want to see. Once you get over 20%, the engine is basically toast. You're losing 20% of your intake charge, plus lowering your compression ratio, you can imagine the power loss. A fresh race engien might get down to less than 5% leakage, but no engine will ever be leak-free.
Mike
Click here to e-mail me!
