TwinTurbo.NET: Nissan 300ZX forum - spray with WD40 to let connectors slide. Slide connectors
mpbond(STL)
on November 09, 2006 at 10:27 PM
Hard pipes
posted by Zski
on November 09, 2006 at 10:19 PM
all the way onto the pipes, lower pipes into position, then slide connectors into position. Done.
Hard pipes
Zski
22:19:00 11/09/06
spray with WD40 to let connectors slide. Slide connectors -
mpbond(STL)
22:27:40 11/09/06
2nd (n/m)
RHulme
22:32:10 11/09/06
Well
94BlackFairladyZ
22:32:01 11/09/06
I don't rec'd that b/c a lot of times you need to readjust
Scotts94z32
16:06:07 11/10/06
I use hairspray each and every time I remove my ic pipes
dogpile
18:09:41 11/10/06
Windex (n/m)
ZonaZ
22:34:25 11/09/06
2nd
Dallas DamonZ
23:21:43 11/09/06
it's the main reason I went with the stillen
moxie
23:34:25 11/09/06
nevermind that hardpipes are gay (n/m)
Guapo
23:36:50 11/09/06
well, naturally (n/m)
moxie
23:40:39 11/09/06
i think being gay might be genetic (n/m)
Zeorymer (Albany)
23:53:30 11/09/06
If that's the case, then hellooooo thailor! (n/m)
Scotts94z32
16:06:54 11/10/06
yup (n/m)
Zeorymer (Albany)
23:53:52 11/09/06
If you dont feel comfortable with spraying WD40
Kong ZTT GT28R MD
22:58:17 11/09/06
2nd alittle WD goes along way.... (n/m)
Booster (MD)
23:47:51 11/09/06
use petroleum jelly (n/m)
RedSER13
23:09:28 11/09/06
Did you try installing them first? It's pretty
Dustin
00:05:36 11/10/06
Seriously...
Cincyzx
00:15:05 11/10/06
Apparantly enough for manufacturors to put directions on
Di Lo
01:15:14 11/10/06
haha that's the truth
jaku
01:39:58 11/10/06
Thanks man
Cincyzx
01:52:28 11/10/06
Re: Seriously...
thejones (Sacto, CA)
11:18:41 11/10/06
The windex in the shade is easiest, but the heat can't hurt
Scotts94z32
16:08:18 11/10/06
Flavored water based lube (n/m)
10:02:55 11/10/06
2nd.
CatnipZ
11:24:09 11/10/06
