TwinTurbo.NET: Nissan 300ZX forum - Timing belt jumps can cuase power loss...
Subject Timing belt jumps can cuase power loss...
Posted by TURBO GAGE on October 11, 2006 at 7:39 PM
  This message has been viewed 56 times.
In Reply To Are you in time on your t-belt? posted by Spddracer on October 11, 2006 at 06:49 PM
Message if it has jumped a tooth, you'll know when you line up all the marks ... they should all fall on there dots... if an even one has jumped a tooth, it equates to an 11 degree advancement or retardation of the cam lobes... which can cause a drop significant drop in power... other things to check during the runs...
fuel pressure at high boost - not just at idle... voltage/ampreage to coils...
pressure check the system for 10-15psi - higher boost can open up leaks that low boost will not...
good luck man..
and the log file is not loading up...
