TwinTurbo.NET: Nissan 300ZX forum - Higher springs rates do help some
Subject Higher springs rates do help some
Posted by Zster (Big Red) on August 21, 2006 at 1:10 PM
  This message has been viewed 107 times.
In Reply To Those spring rates are key to being able to run those wheels posted by RSR on August 21, 2006 at 09:28 AM
Message but my current rates, for this car, the way I drive are far too low. 600/400 is way too soft, I have heavy roll (especially in the front, I'm almost thinking that convential Stillen aftermarket sway bars may not be thick enough for my goals). The way I turn in and brake (maybe someday you'll ride with me at a ZCON and see) does not control the car's weight well.
For the rear, light inner fender modification and some lower control arm modification (with thinner diameter springs/coilovers) allow me to run the wheel.
But other major factors include camber and toe, and overall tire diameter/ride height.
On the front, tire diameter is very important along with camber angles to fit the wheel under the fender (assuming you are able to use the camber).
Cheers,
Salah
Aztec Red 300ZX Twin Turbo
Platinum Mist Metallic 300ZX 2+2
Schwarz II BMW 750iL
