TwinTurbo.NET: Nissan 300ZX forum - Scott - it looks like the low fluid level sensor is not
Subject Scott - it looks like the low fluid level sensor is not
Posted by The Devils Z on August 08, 2006 at 1:49 PM
  This message has been viewed 36 times.
In Reply To I will check the invoices and get back with you. (n/m) posted by The Devils Z on August 08, 2006 at 11:45 AM
Message necessary if you have the safe injection module which was sold in the kit because it determines the fluid level by fluid flow. If you still want the low fluid level indicator, I can acquire that also. Contact me and I will let you know what the cost is.
Safe Injection Module Operation
"The SI-10 and SI-05 monitor the flow of Water/Methanol in the system. When flow drops below 0.10 Gallons per Minute (GPM), equal to 378 ml/min,( 0.05 GPM or175ml/min on the SI-05) the fault trigger will go to a high state of 12 volts. In addition to the supplied red LED, this trigger can be used to signal the following:
1. an ignition/timing controller such as an MSD timing computer if using an MSD ignition
2. aftermarket engine computer
3. a solenoid such that boost is reduced in a wastegated turbo set-up. ( $39.95 list. See below.)
4. a solenoid to evacuate boost on a supercharged set-up.
The trigger signal can deliver up to 1.5 amps to drive a solenoid or relay. "
=============Sig begins here================
The Devils Z.com
"....Thanks captain obvious, would you recommend air to resolve a low tire pressure situation? coolant to keep temps down? perhaps a battery for electrical devices? " ... LJZTT on June 10, 2006 at 6:36 PM
"How the hell would you have gotten on the track had you not *somehow* purchased a ticket? He's so overzealous about making other people look bad, that he sticks both feet down his throat. It's fun to watch though :) " ....ZEngineer on June 07, 2006 at 6:22 PM
"as useless as an EGT Gauge..." *shakes head* Its comments
like this that hold the Z32 community back. " ....Z-Jay (Edmonton, AB) on April 21, 2006 at 11:46 AM
"Somebody give this man a medal. Arguing with kenny is like being in the special olympics" ....ENVYMYZ on November 01, 2005 at 11:59 PM
" .. going back and forth with you on a stupid point is like watching a retarded kid double dribble in basketball, you get tired of calling foul all day" ... Slowninja(GT28RS Inconel Z) on October 03, 2005 at 8:43 AM
"the only chips you know about are Doritos. =)" ...ZEngineer on June 11, 2005 at 4:23 PM
"....These posts only serve to make you look even worse, its gotten so bad it even makes me look bad to reply to you...." maglito on January 22, 2005 at 3:11 AM
"What, are you afraid that only a couple of good ones have rolled off the production lines and the rest are crap?? ... Its mechanics not the stockmarket." ... ZisLuv on May 03, 2004 at 6:12 PM
Z32 Power.Com
Dyno
The Devils Z
The Demon Z (in progress)
View Me!
