| Message |
Here's an excerpt from Ash's "Dyno Dissertation" "When I converted my non-turbo to turbo, I used the non-turbo fuel pump. It worked great at ~14psi. However, when I raised the boost to 16psi on the non-turbo pump, as the RPM increased to around 5500RPM, I began noticing the fuel pressure falling off all the way down to 45psi! This is VERY BAD! The reason this occurred is because the non-turbo fuel pump was unable to keep up with the demand of fuel at higher RPM. It maintained ~65psi until around 5000RPM and then sharply fell off at 5500RPM down to 45psi at the fuel rail. This is a catastrophic failure waiting to happen because when the fuel pressure falls, so does the fuel delivery. This is not a problem with the fuel pressure regulator; this was simply the non-turbo pump falling short of what was needed. I corrected this problem by putting a twin-turbo fuel pump into my car."
