| Message |
:Good morning. This is semi tech article #3 in regards to our : Nissan Fuel Delivery system. Here are my previous articles. : These should be considered prerequisites before reading :today’s article. :TZR; Fuel Injector Analysis, Physical Properties of. :TZR; Stock 1990 Fuel Rail Analysis, Passanger Side. :Disclaimer; :First, I want to start of by touching on fuel itself. All :the analysis I will show today, will be based on a fuel rail : at 45pounds of fuel pressure. In real life applications :fuel pressure is dynamic and varies based on fuel delivery :rate. In general, the more fuel you deliver, the less :pressure in the rail. As fuel pressure drops, fuel velocity :rises. In future tech articles, I will show how each fuel :rail functions in worst case conditions of low pressure / :high velocity. This is where the design of a fuel rail :becomes critical. :The intent of this article is to show what the border fuel :rail looks like from the inside out. This thread will be :fairly brief, and questions and comments are always welcomed. :This is the Border Fuel rail as commonly sold as a :performance fuel rail; : :So let’s start off with what I consider as one of two :massive downfalls of this fuel rail. Notice the orientation : of the fuel injectors inlet, versus the fuel rails main :plenum. It's significantly not on plane with the main :plenum. This will become evident as a problem in our :analysis that follows. : :The other issue, that is not shown, is the fact that this :fuel rail is not thermally isolated from the lower plenum. :What does this mean? It means that the metal to metal :contact between the lower plenum that we mount to, and the :fuel rail, allows the fuel rail to accept heat into the fuel : rail and will transfer heat to the fuel. : :In this view, I want you to take notice of the AN6 Male to : Male fitting. The AN designation stands for :"Airforce-Navy" and is a high tolerance military :specification. (AN815 Union,Flared Tube.pdf). :In this specification, you will notice that it refers to :meeting the requirements of MS33656 ("MS33656 Fitting End, :Flared Tube Connection"). This document is very specific :such that the seal that is created by metal to metal contact : is sufficient and ample. :So why do I bring all this up? Because, The border fuel :rail does not utilize these mating surfaces per the fittings : designed intent. As such, (and not shown clarity and model : simplicity), the border fuel requires the use of an O-Ring :to provide your positive seal. Since there is no positive :stop, it is very easy to crush and extrude that O-ring to a : point where it will not provide a seal. : :Analysis TIME! :Here's a general overview from above. Nothing exciting here : really... you can see that the rail and fuel delivery looks : pretty good, eh? Or does it? : :Notice the flow trajectories in comparison to the inlet of :the Denso/Sard 850 Fuel injector? : :Let’s take a look from the top... Uh oh... No flow from this : view either... : : : :And a bonus shot : :Remember, at 45psi, none of this is a big deal. On your :stock car, you'd be fine with any fuel rail product. But :for those of us who modify our cars, we really need a fuel :rail that can provide fuel at worst case conditions. This :is where Damon and I picked up the ball and produced a :performance fuel rail that addressed all the discrepancies :we found through multiple analysis methods. We hope you :like our product. :No later then next week, I will present you a flow analysis :of fuel injectors in the 300degree fuel rail. This will :relate to my original Fuel Injector Clocking technical :article. We will come full circle.you are correct, they should require at least a science class before reading this message. :
