Good morning. This is semi tech article #3 in regards to our Nissan Fuel Delivery system. Here are my previous articles. These should be considered prerequisites before reading today’s article.TZR; Fuel Injector Analysis, Physical Properties of. TZR; Stock 1990 Fuel Rail Analysis, Passanger Side. Disclaimer; First, I want to start of by touching on fuel itself. All the analysis I will show today, will be based on a fuel rail at 45pounds of fuel pressure. In real life applications fuel pressure is dynamic and varies based on fuel delivery rate. In general, the more fuel you deliver, the less pressure in the rail. As fuel pressure drops, fuel velocity rises. In future tech articles, I will show how each fuel rail functions in worst case conditions of low pressure / high velocity. This is where the design of a fuel rail becomes critical. The intent of this article is to show what the border fuel rail looks like from the inside out. This thread will be fairly brief, and questions and comments are always welcomed. This is the Border Fuel rail as commonly sold as a performance fuel rail;
So let’s start off with what I consider as one of two massive downfalls of this fuel rail. Notice the orientation of the fuel injectors inlet, versus the fuel rails main plenum. It's significantly not on plane with the main plenum. This will become evident as a problem in our analysis that follows.
The other issue, that is not shown, is the fact that this fuel rail is not thermally isolated from the lower plenum. What does this mean? It means that the metal to metal contact between the lower plenum that we mount to, and the fuel rail, allows the fuel rail to accept heat into the fuel rail and will transfer heat to the fuel.
In this view, I want you to take notice of the AN6 Male to Male fitting. The AN designation stands for "Airforce-Navy" and is a high tolerance military specification. (AN815 Union,Flared Tube.pdf). In this specification, you will notice that it refers to meeting the requirements of MS33656 ("MS33656 Fitting End, Flared Tube Connection"). This document is very specific such that the seal that is created by metal to metal contact is sufficient and ample. So why do I bring all this up? Because, The border fuel rail does not utilize these mating surfaces per the fittings designed intent. As such, (and not shown clarity and model simplicity), the border fuel requires the use of an O-Ring to provide your positive seal. Since there is no positive stop, it is very easy to crush and extrude that O-ring to a point where it will not provide a seal.
Analysis TIME! Here's a general overview from above. Nothing exciting here really... you can see that the rail and fuel delivery looks pretty good, eh? Or does it?
Notice the flow trajectories in comparison to the inlet of the Denso/Sard 850 Fuel injector?
Let’s take a look from the top... Uh oh... No flow from this view either...
And a bonus shot
Remember, at 45psi, none of this is a big deal. On your stock car, you'd be fine with any fuel rail product. But for those of us who modify our cars, we really need a fuel rail that can provide fuel at worst case conditions. This is where Damon and I picked up the ball and produced a performance fuel rail that addressed all the discrepancies we found through multiple analysis methods. We hope you like our product. No later then next week, I will present you a flow analysis of fuel injectors in the 300degree fuel rail. This will relate to my original Fuel Injector Clocking technical article. We will come full circle.
Petz #3
