TwinTurbo.NET: Nissan 300ZX forum - Idling at a stand still is the worst way to build heat...
Subject Idling at a stand still is the worst way to build heat...
Posted by Black95 on June 08, 2006 at 5:31 PM
  This message has been viewed 46 times.
In Reply To Just rana ECU diagnostic posted by JayT on June 08, 2006 at 04:59 PM
Message in any car. Caused by the reduced airflow around the engine. Then shutting the engine off shuts the fan down as well and leads to "heat soak" further increasing the temperature.
If you've ever had a vehicle with a bad fan clutch (not a Z), you would probably not have noticed anything cruising at highway speeds as the fan clutch is essentially useless above 60-80 km/h due to the outside airflow (depending on car and conditions). You find out its bad when stuck in a traffic jam or idling outside a store as the heat just continues to build.
I think these guys are trying to tell you that all this excessive heat made your engine "think" it sensed knock or detonation. Correct me if I'm wrong.
