Disclaimer; These are just general ideas on plumbing your Z32 in different configurations. Additional research or configuration changes may be needed to suite your needs.
Here we have your standard OEM Serial configuration. In this configuration you are using stock fuel accessories, retrofiting rubber high pressure fuel lines as commonly seen on stock Z32s.
In the following configuration, we are using all AN hardware in a standard OEM serial configuration. We install a high performance fuel pressure regulator.
Now we get into some fun. When we designed this kit, we really wanted to focus on performance. One of the aspects of the Z32 that's rough is the fact it's a serial feed system. In high performance applications it's feasible that you get fuel starvation in cylinders four and six. Detonation due to fuel starvation in #6 is one of the most common forms of engine failures. In this case, I chose to go parallel, but use stock OEM fuel accessories.
And finally, we get to "the meat". Full AN hardware, AN fuel accessories, and the 300Degree fuel rail. For performance applications and maximum safety, this is the motherload.
I hope this quick 'generalization' of fuel system configurations and the flexability of the 300degree fuel rails was educational.
Petz #3
