TwinTurbo.NET: Nissan 300ZX forum - FWIW - I really do NOT recommend deleting the fuel hard line
Subject FWIW - I really do NOT recommend deleting the fuel hard line
Posted by YugoBernie (NoVA) on May 04, 2006 at 2:23 PM
  This message has been viewed 140 times.
In Reply To What are you talking about? The hard fuel line bypass? posted by Milo (San Antonio) on May 04, 2006 at 02:07 PM
Message Fuel lines should never rest on the motor or "rub" around. Braided or not. The hard lines have a vac. galley on them as well that @ least needs to be replaced w. a hose. The stock set up keeps fuel lines off the motor and the ones that could @ some point come in contact w. hood, inside fender etc have the secondary plastic sheeting on them. It is also not a good practice to run long lengths of high pressure fuel lines because you expose yourself to larger risk of leaks. I don't think there is any length of on the car greater then 18inchs or so.
IMHO removing the hard lines is a "lazy" mod, rather then rebuilding the fuel set up correctly.
YugoBernie
