TwinTurbo.NET: Nissan 300ZX forum - Depends. If the fuel rail sensor is hot enough, it will
Subject Depends. If the fuel rail sensor is hot enough, it will
Posted by Ash's Z on April 20, 2006 at 3:39 PM
  This message has been viewed 289 times.
In Reply To So why does her pump run @ 14v from the second you start? (n/m) posted by YugoBernie (NoVA) on April 20, 2006 at 01:26 PM
Message put the pump into high speed mode regardless of throttle position for a predetermined amount of time. I recall when I listened to her car that the pump was changing speeds when she cracked the throttle a little, so it appears to me that at least that part of the control system is working properly. Even at 14V, the pump shouldn't make all that noise. Even with a ton of noise on the pump's power line, it isn't going to make it resonate like that, which leads me back to it having to be something mechanical.
[ ashspecz.com ]
[ agpowers@bellsouth.net ]
Enthusiasts soon understand each other. --W. Irving.
Are you an enthusiast?
If you are out to describe the truth, leave elegance to the tailor.
Albert Einstein
