TwinTurbo.NET: Nissan 300ZX forum - exhaust is leaking ...and will cause carbon build up
Subject exhaust is leaking ...and will cause carbon build up
Posted by genic on January 19, 2006 at 9:26 PM
  This message has been viewed 234 times.
In Reply To Exhaust manifold gasket leaking posted by a-town z on January 19, 2006 at 08:19 PM
Message on the engine/heads...plus will really raise the temps around the manifolds. its not good.
question...how did you find out they are leaking? the dealer told you? i would get a second opinion...NOT FROM A DEALER.
you typically have to pull the engine to remove the manifolds. if you fill out your profile..we will know if you have a NA or not. NA's have easier manifolds to remove and can be done without removing the engine.
all your hoses wont melt...but it will cause higher temps (depending on the leak size) in the engine bay. that can cause problems with many different things.
its something you want to get fixed.
