TwinTurbo.NET: Nissan 300ZX forum - Cam duration and lift affects a motor's compression
Subject Cam duration and lift affects a motor's compression
Posted by AzHeat on October 29, 2005 at 12:40 PM
  This message has been viewed 68 times.
In Reply To compression ratio (as he was referring too) has nothing to posted by jkperformance on October 29, 2005 at 12:19 PM
Message depending on the size of the cam and also what rpm range. A long duration cam will have lower compression numbers in the bottom rpm range. When you do a compression test at starter speed, the long duration cam will give lower readings that a stock cam. The compression ratio is a mechanical ratio which has nothing to do with how well the motor breathes.
