TwinTurbo.NET: Nissan 300ZX forum - forced induction compretion is more efficient than N/A>>>>
madtdogs
on October 29, 2005 at 8:16 AM
Just wondering?
posted by Andrew(nj)
on October 29, 2005 at 03:54 AM
if you lower the compression you can run more boost on lower octaine fuel before the engine "knocks" and more boost= more power
Just wondering?
Andrew(nj)
03:54:09 10/29/05
I believe Mark Leader (sirpriz) raised his compression, lets
Eishozzzz
06:04:05 10/29/05
yep, he is running 9:1 (n/m)
aliaZ
09:32:17 10/29/05
I copied you, in fact I took your engine, you haven't
SirpriZ
18:33:30 10/29/05
if you raise the CR, you can't run as much boost.
Marshall
08:04:33 10/29/05
Hi Marshall, My understanding is that boost nets more
SirpriZ
19:20:03 10/29/05
"Nets more torque THAN by raising the CR." (n/m)
SirpriZ
19:23:07 10/29/05
on my red car i ran 9>1
Z32POWER.com
08:09:51 10/29/05
what kind of boost were you able to run on pump gas? 9:1 (n/m)
AntiHero
11:20:04 10/29/05
i never really pushed it, i just ran 17 for safety (n/m)
Z32POWER.com
12:19:10 10/29/05
forced induction compretion is more efficient than N/A>>>> -
madtdogs
08:16:15 10/29/05
most people dont run enough boost though
AntiHero
10:07:53 10/29/05
Would you consider the GT2860RS turbo's small-medium sized?
MOTRSPRT--ID
19:28:00 10/29/05
it's a little more complicated than that (n/m)
mousersix (San Antonio)
11:40:28 10/29/05
yeah.... didnt feel like typing an hour long post ... srry (n/m)
madtdogs
07:03:23 10/30/05
I'm running 9.2:1
aliaZ
09:35:24 10/29/05
When you compression test your engine what kind
EricTTZ
09:41:31 10/29/05
well
aliaZ
10:48:27 10/29/05
with longer duration cams, you compression should drop. (n/m)
AzHeat
11:25:58 10/29/05
good point (n/m)
aliaZ
11:34:25 10/29/05
Anyone running Wiseco pistons has 8.8:1 compression---->
Kyle(Houston)
09:45:28 10/29/05
yes...
AntiHero
10:05:59 10/29/05
You will blow your engine up...
Scotts94z32
10:28:50 10/29/05
serisouly asking...
AntiHero
10:33:28 10/29/05
No, I do not.
Scotts94z32
10:45:29 10/29/05
long gone..
AntiHero
10:56:14 10/29/05
You'll probably never find out, either.
Marshall
11:04:44 10/29/05
Hi Scott, I'm actually going to weld the wastegates
SirpriZ
18:52:40 10/29/05
Hi Mark your crazy, talk to you later. lol!!!! Lee (n/m)
lewoolf2
22:52:00 10/29/05
Here is my experience...
AzHeat
11:59:25 10/29/05
i dont get it...
AntiHero
12:20:29 10/29/05
I am also running 500rwhp. I have more power and
AzHeat
12:32:33 10/29/05
Isn't 91 octane wonderful? On paper, the 8:1 CR and
SirpriZ
18:42:54 10/29/05
Yea, 91 octane sucks. (n/m)
AzHeat
19:14:15 10/29/05
i believe member aliaz runs over 9:1 compression and is
CollegeBoy
10:39:25 10/29/05
lol..woops. he already stated that above sorry. (n/m)
CollegeBoy
10:40:27 10/29/05
He is also running bigger cams. That affect compression
AzHeat
11:34:29 10/29/05
compression ratio (as he was referring too) has nothing to
jkperformance
12:19:07 10/29/05
Cam duration and lift affects a motor's compression
AzHeat
12:40:56 10/29/05
exactly, which is why the cams don't change the
jkperformance
12:50:27 10/29/05
i'll be going with a little more compression then AliaZ
ni[X]it
21:39:14 10/29/05
