TwinTurbo.NET: Nissan 300ZX forum - SZR - How would I go about running a power wire
Subject SZR - How would I go about running a power wire
Posted by Slowninja(GT28RS Inconel Z) on August 16, 2005 at 12:10 PM
  This message has been viewed 49 times.
Message straight to the battery with an inline fuse? This question may answer itself so I acknowledge that it maybe a stupid question .. I wanted to know what part / fuse type setup would I need ..I already have the wire in mind ..is this something that I can buy from a place like a pepboys / radio shack / autozone ... I don't know off of the top of my head what amperage or volts it needs to support --but the wire is used to drive the power to my water injection setup. I want the inline fuse to avoid the wire catching on fire if it is haphazardly spliced and touches the frame anywhere. Thanks for your responses. If you reply with a link to the part that you are talking about - that will be great !
=============Sig begins here================
"the only chips you know about are Doritos. =)" ...ZEngineer on June 11, 2005 at 4:23 PM
"... Installing the ES bushing was a huge pain for me because it's so stiff. I like the way it feels once installed, but if I had to do it over again, I'd get the OEM ... it's soft enough to flex right into place ".... 300ZMang on May 05, 2005 at 10:47 AM
"What, are you afraid that only a couple of good ones have rolled off the production lines and the rest are crap?? ... Its mechanics not the stockmarket." ... ZisLuv on May 03, 2004 at 6:12 PM
"....I think you need to lay off the sauce or whatever you have driving you nuts and take it easy for a while. These posts only serve to make you look even worse, its gotten so bad it even makes me look bad to reply to you...." maglito on January 22, 2005 at 3:11 AM
"You think when you go to a bar with your girlfriend, every other guy there is gonna be your best friend? Welcome to reality." ........ dilo on January 04, 2005 at 4:02 PM
Z32 Power.Com
pump fuel :
519 rwhp / 502 torque
sunoco 104 race fuel :
604 rwhp / 544 torque
Dyno Charts -
Dyno
La-Z-Link
La-Z-Link
