TwinTurbo.NET: Nissan 300ZX forum - r u sure that electric motor will handle the heat of the fan
Subject r u sure that electric motor will handle the heat of the fan
Posted by PLEAZURE in CA (SD) on August 12, 2005 at 3:55 PM
  This message has been viewed 43 times.
In Reply To AshsZ-II "Ultimate Street Z Buildup" Electric Water Pump >> posted by Ash's Z on August 12, 2005 at 01:03 PM
Message blowing very hot air on it !
Heat is the biggest factor that would cause an electric motor to blow.
Also how do you guarantee that the water wont leak through the shaft seal behind the propeller, since the heat from the coolant in addition to the rotational friction are going to wreck havoc on it .. you better have one hell of a seal.
Just the 2 issues I wanted to point out ..
good luck with your experiment.
Al "Kelly turn the car on."
Bud "Maybe you should tell her to use the key before she starts rubbing the car"
Al "Bud, your sister isn't that dumb. Pumpkin use the key."
PLEAZURE in SD
Matt
91TT Aztec Red stg IV+
