TwinTurbo.NET: Nissan 300ZX forum - Detonation is more a factor of ignition timing and fuel
Subject Detonation is more a factor of ignition timing and fuel
Posted by Ash's Z on August 07, 2005 at 1:06 PM
  This message has been viewed 71 times.
In Reply To I haven't had any detonation to reduce :) posted by ConVerTT on August 07, 2005 at 12:42 PM
Message octane and a lot less to do with A/F. You are only running ~8psi of boost pressure, which is pretty low. I know the NA motor makes good power at 8psi of pressure, but there is still a good bit of boost in the turbos that you aren't tapping. Water injection will allow you to turn up the boost some more without detonation.
I'm just making a suggestion to you here - I've tuned the turbo'd NA engine before and I've played with water injection extensively. You will stand to benefit greatly from the use of water injection on the high-compression NA engine. It will add a degree of safety to your combination as well as allow you to turn up the boost a little more.
[ ashspecz.com ]
[ agpowers@bellsouth.net ]
Enthusiasts soon understand each other. --W. Irving.
Are you an enthusiast?
If you are out to describe the truth, leave elegance to the tailor.
Albert Einstein
