| I have abnormal tire wear on front tires - less than 10k miles on the tires -- all other thread is good ... second time I had this issue now ..the first fix a few years ago was to get new Eibach springs / 300 degree camber kit / new stock front upper a-arms / stillen tension rods ( also have sway bars and strut tower bar and new OEM shocks - replaced with my Eibach springs )... ... got the car re-aligned at a reputable shop about a year ago when I got new sneaks haven't been driving the much until past 2 months or so - maybe 10k past year or so... with this setup what would could cause excessive inner tire wear ? The stock front arms are not "mushy" / loose ( checked it ). I made an appointment with the same reputable alignment shop (they use lasers to align the car ) - the earliest I can get in is mid-august. Don't feel comfortable taking it to a pepboys or NTB. I am assuming that the alignment a year ago was done correctly. I will post the measurements later. Could the Eibach springs be sagging more than .8 inch drop ( they have about 20-40k on them - can't remember )? Any other suggestions besides wait to compare prior and current measurements ? Just wondering if there are any other suspension parts I should check for abnormal wear. Thanks
=============Sig begins here================ "the only chips you know about are Doritos. =)" ...ZEngineer on June 11, 2005 at 4:23 PM "... Installing the ES bushing was a huge pain for me because it's so stiff. I like the way it feels once installed, but if I had to do it over again, I'd get the OEM ... it's soft enough to flex right into place ".... 300ZMang on May 05, 2005 at 10:47 AM "What, are you afraid that only a couple of good ones have rolled off the production lines and the rest are crap?? ... Its mechanics not the stockmarket." ... ZisLuv on May 03, 2004 at 6:12 PM "....I think you need to lay off the sauce or whatever you have driving you nuts and take it easy for a while. These posts only serve to make you look even worse, its gotten so bad it even makes me look bad to reply to you...." maglito on January 22, 2005 at 3:11 AM "You think when you go to a bar with your girlfriend, every other guy there is gonna be your best friend? Welcome to reality." ........ dilo on January 04, 2005 at 4:02 PM
Z32 Power.Com pump fuel : 519 rwhp / 502 torque
sunoco 104 race fuel : 604 rwhp / 544 torque Dyno Charts - Dyno La-Z-Link La-Z-Link
"No matter how good she looks, there's some guy out there that is tired of dealing with her ass "
