TwinTurbo.NET: Nissan 300ZX forum - Where/What is a TT fuel pump controller? (n/m)
ChrisZNA (Sacto, CA)
on March 25, 2005 at 10:46 PM
TT fuel pump and TT fuel pump controller also (n/m)
posted by Zeus
on March 25, 2005 at 05:17 PM
Need some input...
16:43:49 03/25/05
I dont see a EFI harness in there.....
BOOZTD 3
16:45:31 03/25/05
You will probably want to examine your motor mounts too (n/m)
BOOZTD 3
16:53:57 03/25/05
never done the swap but
ZXRider(SoCal)
16:46:20 03/25/05
Rear main seal, EFI harness, engine mounts, water lines
YugoBernie (NoVA)
16:55:11 03/25/05
Are OEM motor mounts or urethane better? (n/m)
22:50:30 03/25/05
urethane (n/m)
NytWolf
00:34:17 03/26/05
If you are doing your clutch, you might as well add a
Unluky (MO)
16:56:59 03/25/05
bypass ur egr, easy access with motor out
DragonSi
17:12:50 03/25/05
Zeus
17:17:30 03/25/05
Where/What is a TT fuel pump controller? (n/m) -
22:46:27 03/25/05
most def do an EFI harness ... and you'll want some
Guapo
17:18:13 03/25/05
EFI Harness...fire hazard if u dont!!!!!! DO IT! (n/m)
Borg79(ON)
17:55:14 03/25/05
while my engine was out i did some stuff in the engine bay
mousersix (San Antonio)
18:45:55 03/25/05
Is there a right up on the water line delete? If EGR and
22:48:31 03/25/05
yep, its in FAQ
13:04:30 03/26/05
Replace coolant hose on the back of engine while it's out
doug8867
19:07:57 03/25/05
reference picture inside >>
Zeus
19:49:31 03/25/05
Re: Need some input...
Dlee300z
19:20:59 03/25/05
