TwinTurbo.NET: Nissan 300ZX forum - There won't be hot oil in the car...the only way it would be
jkperformance
on February 10, 2005 at 11:47 AM
Re:I wouldn't run a hot oilline inside the car!!! (n/m)
posted by nowayout
on February 10, 2005 at 11:44 AM
hot in there would be if it were flowing through, but since it's just pushing, after bleeding out the line the first time, it retains that oil and it doesn't heat up the whole way in.
-John
when installing a mechanical oil pressure gauge (not an elec
zebra
11:40:38 02/10/05
nowayout
11:44:40 02/10/05
There won't be hot oil in the car...the only way it would be -
jkperformance
11:47:51 02/10/05
haha.. yeah right. heat travels through fluids.
Red October
11:56:51 02/10/05
true...the heat travels through it in convection currents
jkperformance
12:06:09 02/10/05
no, some heat will dissipate
Red October
12:44:06 02/10/05
unless the line ruptures
aliaZ
11:57:16 02/10/05
As have I, had to pull the dash to clean it all out (n/m)
jkperformance
12:06:43 02/10/05
You can connect it to either side of the engine.
SniPer SR71 (Dallas)
11:54:04 02/10/05
as long as it clears....
Zluster(Project Platypus)
13:09:05 02/10/05
I installed a Tee fitting where the sending unit
AzHeat
14:24:41 02/10/05
