TwinTurbo.NET: Nissan 300ZX forum - Whoa, 41 psi cold is way, way too high!
Subject Whoa, 41 psi cold is way, way too high!
Posted by Zster (Big Red) on February 01, 2005 at 2:42 PM
  This message has been viewed 95 times.
In Reply To Kumho Victoracers 245/45/16 posted by Rob'Z on February 01, 2005 at 02:31 PM
Message You should be 30-40 hot, depending on what you like and what you expect from the tire!
Are you slotted rotors? How do the rotors look do you see blotches of pad material or is it uniform dark around the rotor?
At 41 cold, probably 45-46 hot, you shouldn't be having tire roll over, esp on victoracers; However, it depends on the track surface if the front are skipping. Is this on hot laps or cold laps? Whats the surface like?
Did you check all your multilink to see if the upper arms and t-rods are still tight?
Cheers,
Salah
Aztec Red 300ZX Twin Turbo
Platinum Mist Metallic 300ZX 2+2
