The HP and torque lines for any given run must intersect at 5252 rpm. This is because the HP is calculated from torque using the equation
HP=torque*rpm/5252.
In these curves, this is only true of the curves at 23 psi. All others are off, some by quite a bit. You might want to check with the shop to see if this can be resolved.
