TwinTurbo.NET: Nissan 300ZX forum - Well - I followed the clutch replacement FAQ but >>>
Subject Well - I followed the clutch replacement FAQ but >>>
Posted by ConVerTT on January 19, 2005 at 1:35 PM
  This message has been viewed 46 times.
In Reply To What is the problem with the top two bolts? Did you posted by AzHeat on January 19, 2005 at 01:12 PM
Message The FAQ talks about dropping the driver's side transmission support bracket and then using the 3ft extension and swivel to remove the bolts. This did not work for me at all. The 3ft extension kept binding between the bell housing and the body. I ended up removing both sides of the transmission support bracket, then using the T-jack to lower the transmission a little further, and then getting to the bolts from the side/back of the bell housing with a 2ft extensionand the swivel.
ConVerTT - Heading to the DarkZide
Black Vert Pics Pearl Vert Pics
