TwinTurbo.NET: Nissan 300ZX forum - Re: fuel cut rev limiter or anything that regulates engine R
Subject Re: fuel cut rev limiter or anything that regulates engine R
Posted by ni[X]it on January 17, 2005 at 11:01 PM
  This message has been viewed 132 times.
In Reply To fuel cut rev limiter or anything that regulates engine RPM posted by Ash's Z on January 17, 2005 at 10:14 PM
Message fuel cut is safer.
the excess fuel burned doesnt generate any heat or "power".
you can burn lean so long as you arent generating power.
ignition cut is not safer.
ignition cut sends a bunch of raw fuel into your exahust/turbos potentially causing combustion in the exhaust/turbos. any raw fuel that gets past there will only damage your o2 sensors.
ideally, you'd want both.
"As the Z32 gets older and decreases in value it becomes affordable by lower income and often less desirable people whose tastes reflect their personality and social standing.- Marshall 17:37:05 10/10/03
Petz #3
