TwinTurbo.NET: Nissan 300ZX forum - fuel cut rev limiter or anything that regulates engine RPM
Subject fuel cut rev limiter or anything that regulates engine RPM
Posted by Ash's Z on January 17, 2005 at 10:14 PM
  This message has been viewed 203 times.
In Reply To Thank you, by cutting ignition or both what kind of damage posted by Eishozzz on January 17, 2005 at 10:03 PM
Message by cutting fuel is a big NO-NO. There is always some residual fuel left in the intake runner and if you cut the fuel to reduce the engine RPM, you will cause the cylinders to have a few power strokes of very lean condition. The 350Z uses fuel cut rev limiting, and you would not want to bounce that car off the rev limiter for any length of time what-so-ever. They went to this setup though because of emissions; an ignition cut setup produces a lot of execss hydrocarbon in the exhaust, but it is a very safe way of limiting RPM.
[ ashspecz.com ]
[ agpowers@bellsouth.net ]
Enthusiasts soon understand each other. --W. Irving.
Are you an enthusiast?
If you are out to describe the truth, leave elegance to the tailor.
Albert Einstein
