TwinTurbo.NET: Nissan 300ZX forum - Pressure washer attached to a hot-water heater.
Subject Pressure washer attached to a hot-water heater.
Posted by Ash's Z on December 10, 2004 at 4:57 PM
  This message has been viewed 212 times.
In Reply To how did you strip the undercarriage? posted by genic on December 10, 2004 at 04:53 PM
Message No chemicals were used. The undercarriage is already coated with a good bit of urethane that holds very well to the metal and the rubber blasts away pretty easily. After everything dried after blasting, I wiped the entire undercarriage down with a rag soaked in Laquer thinner to remove the left-over residue of the rubber and prepare the surface for the herculiner.
[ ashspecz.com ]
[ agpowers@bellsouth.net ]
Enthusiasts soon understand each other. --W. Irving.
Are you an enthusiast?
If you are out to describe the truth, leave elegance to the tailor.
Albert Einstein
