TwinTurbo.NET: Nissan 300ZX forum - Re: Any more technical insight than that? ;-)
Subject Re: Any more technical insight than that? ;-)
Posted by HKS 2835 on November 05, 2004 at 11:44 AM
  This message has been viewed 29 times.
In Reply To Any more technical insight than that? ;-) (n/m) posted by boileralum on November 05, 2004 at 11:32 AM
Message Just do a quick leak test. Make sure all the valves are close. Put a little water on the top of the valve to see if it drips through. Or use a pressure test if you have. The machine shop use water to check for leak on my heads. Which worked great becuase I found three of then leaking.
