TwinTurbo.NET: Nissan 300ZX forum - high idle after running at Hallett...
Subject high idle after running at Hallett...
Posted by Tu on October 26, 2004 at 12:41 PM
  This message has been viewed 122 times.
In Reply To Post ONE annoying thing your Z does and you can't figure out posted by SeedyROM on October 26, 2004 at 12:18 PM
Message First 2 runs car ran great... before the 3rd run I went and filled up with supposed super unleaded. Next run it pinged all over the track.... but still idled fine. Before the last run I put in about 3 gallons of race gas... pings were gone, car ran great... but after the run the car idles around 1400-1600.
I have... cleaned the tb's, reset the tps, cleaned as many connections as I can get to, replaced the temp probe, tested numerous times for vacuum leaks, the iaa and the air regulator valve both tested fine with the multimeter... Guess looking at/replacing the spark plugs is next.
I'm running out of easy things to test.
Be seeing you.Tu.frustrated.
Bad spellers of the world. UNTIE!
