TwinTurbo.NET: Nissan 300ZX forum - I think the 1S system does not need a ecu upgrade>>>
Subject I think the 1S system does not need a ecu upgrade>>>
Posted by NISMOtt on February 21, 2001 at 1:15 PM
  This message has been viewed 19 times.
In Reply To great price...BUT...>> posted by nixit(4:20 blues) on February 21, 2001 at 12:48 PM
Message according to the A-Mist web site info, the 1S system comes with an adjustable pressure setting that lets you set what psi the system should kick in at, and the range is from 3-30psi, the one used on the SCC project is most likely a higher model because it's linked directly with the ecu, and is probably more of a competition set-up.
In my opinion the 1S system will be perfect for me, this way I would not have to retard the timing to avoid detonation and lose power at the same time. Only thing is, I don't think the windshield washer reservoir will be big enough cause the web site recommends 10-25% of capacity of your gas tank, unless I carry a 4L jug of water around in the car or use a bigger reservoir
