TwinTurbo.NET: Nissan 300ZX forum - Why? Zemulator is cheap, easy to use, and easy to install...
Subject Why? Zemulator is cheap, easy to use, and easy to install...
Posted by Borg79(ON) on September 22, 2004 at 1:03 PM
  This message has been viewed 42 times.
In Reply To Motec screenshots (lots of pics) posted by ZisLuv on September 22, 2004 at 08:49 AM
Message and probably just about as useful as that unless u go super extreme...i couldnt justify 4 g's on that unless it was a 1100+hp car...cuz russell's car did FINE with the stock ecu at 1050RWHP....*scratch head*
Gotta make a new sig pic...
-"Chains baby, chains.......Z will grip like a champ. (n/m) - Wolf [Pittsburgh] 14:56:58 05/10/00"
How to Check Turbos: "1st remove exhaust and pre-cats. Then fire that mother up, rev it to at least 5000 rpm and then stick your finger into the hole on the back of the turbo. If the turbine grinds your finger down, then your turbo is working. If your finger gets ground off farther than the second knuckle, then your turbos are good for at least another 60k miles! Don't forget to check both sides." -I am Z-ing Double
-"The world's two biggest mysteries: The meaning of life and fitting the Howe radiator into the Z..." -Seedyrom, circa 2000
