TwinTurbo.NET: Nissan 300ZX forum - it would be a better base comparision. By all means not rule
SuparexTT
on August 25, 2004 at 6:50 AM
different cars, engine status, dynos, dyno conditions...
posted by Scotts94z32
on August 25, 2004 at 01:05 AM
There are always variables in any testing situation...even on the same dyno.
Did someone say Carolina Z Club?
Here are my results form my dyno tonight
sgtskiusmc (Generation Z)
22:20:19 08/24/04
Check for boost leaks...
Only1Z
22:22:32 08/24/04
yeah, there are some boost leaks there (n/m)
Guapo
22:31:58 08/24/04
Is the way the Hp tails off a sign of boost leaks? (n/m)
Atl300zxTT
23:01:56 08/24/04
you have a boost leack,last time i dyno my car i managed
Red Baron Z
23:11:07 08/24/04
*leak* (n/m)
Red Baron Z
23:13:23 08/24/04
Wow
BOOZTD 3
00:15:10 08/25/04
yes assuming you are at 16psi...it's a boost leak
SuparexTT
00:28:07 08/25/04
I can send you mine and the other cars dyno sheets if u like (n/m)
SuparexTT
00:30:09 08/25/04
Scotts94z32
01:05:24 08/25/04
granted ... but that is at least a dynojet (common)
Guapo
01:10:56 08/25/04
it would be a better base comparision. By all means not rule -
SuparexTT
06:50:22 08/25/04
Is it me, or are you running lean over 3.5K !?
PLEAZURE in CA (SD)
01:47:49 08/25/04
No, he's *rich* over 3.5k rpm..
AaronJB
04:53:39 08/25/04
Get some Greg Dupree Downpipes and testpipes and...
WhiteOutZ
02:04:28 08/25/04
he "should be" close to that already....boost leaks (n/m)
SuparexTT
06:44:40 08/25/04
His Z even sounded better than the 17psi SC 03 Cobra >>>
Zski (Generation Z)
04:42:03 08/25/04
well that is all that matters then.
Jason(MD)
06:42:32 08/25/04
all 03+ cobras are SC. (n/m)
Mr. Hat
13:30:13 08/25/04
Check your timing and you look way rich.
colocomp (Denver)
07:22:44 08/25/04
Here's my results from 7/04 - not much different than yours.
Dave N
12:53:27 08/25/04
