TwinTurbo.NET: Nissan 300ZX forum - OMG, i about dies when i called for alignment...
SuparexTT
on June 03, 2004 at 4:56 PM
the cost of your alignment can go up the more adjustable
posted by robo (sebring1970)
on June 03, 2004 at 10:09 AM
Right now it's $60-70 . When i tell them i'll have adjustable tension rods and upper arms...they flip and charge $90-120.
what are the benifits-pros,cons to poly bushings over
nd4spd
08:13:34 06/03/04
If you need caster adjustment then you need adjustable
YugoBernie (NoVA)
08:18:15 06/03/04
What's your take on this?
Junxster (NoVA)
08:48:31 06/03/04
Hard to fine tune, you really need adjustment to compenstate
YugoBernie (NoVA)
09:41:29 06/03/04
some would also say the solid bushing adjustable rods
Guapo
08:49:42 06/03/04
I'd say that. (n/m)
Tu
09:00:46 06/03/04
Over stock, but my SPL adjustable rods feel similiar to poly (n/m)
SooperZ95
09:22:13 06/03/04
I dont think i need any adjustments so if the feel and the
nd4spd
09:39:51 06/03/04
Marginal @ best vs. the ES bushings, esp. when you do the
YugoBernie (NoVA)
09:40:14 06/03/04
This guy is obsessed with tension rods and bushings
Ben_96_Slicktop (VA)
09:16:40 06/03/04
2nd. (n/m)
Chaaarmndr (NoVa)
09:23:09 06/03/04
What, you mean you never do that?
SooperZ95
09:23:45 06/03/04
Mechanicality? (n/m)
Black Mammoth (VA)
09:36:52 06/03/04
do you HAVE to use adjustable T-rods if you also have
robo (sebring1970)
09:55:55 06/03/04
they do 2 different things, camber and caster (n/m)
Halo Z
09:58:37 06/03/04
oh yeah, no, you don't hhave to have one, withthe other. (n/m)
Halo Z
09:59:02 06/03/04
Actually, both Courtesy & SPL recommend new T-rods w/ A-arms
SooperZ95
10:11:41 06/03/04
which "bearings" are they talking about? the ones
robo (sebring1970)
10:16:58 06/03/04
Yes, the bearings in the upper arms. That's my take on it. (n/m)
SooperZ95
10:20:26 06/03/04
I'm not sure I make the "connection" (pun intended)
robo (sebring1970)
10:32:40 06/03/04
Re: I'm not sure I make the "connection" (pun intended)
rich@splparts.com
10:48:07 06/03/04
but I can envision it both ways, that the solid T-rods
robo (sebring1970)
13:07:33 06/03/04
Yes. (n/m)
YugoBernie (NoVA)
10:59:54 06/03/04
where are the "bearings" in the upper a arms? (n/m)
Halo Z
12:48:40 06/03/04
Re: where are the "bearings" in the upper a arms?
Guapo
12:54:35 06/03/04
:c) (n/m)
robo (sebring1970)
13:08:31 06/03/04
interesting....
Halo Z
16:38:04 06/03/04
Yes. (n/m)
YugoBernie (NoVA)
17:27:16 06/03/04
recommend is not "needed"
Halo Z
10:34:23 06/03/04
I think your ES bushings would count as "solid type T-rods" (n/m)
SooperZ95
10:44:25 06/03/04
no they don't (n/m)
Guapo
10:47:14 06/03/04
I concurr. Even though the poly's are alot stiffer than
robo (sebring1970)
13:13:32 06/03/04
It's something about the stock/poly bushing...
SuparexTT
16:55:05 06/03/04
So does Midori Seibi (n/m)
PEwithaZ
11:34:32 06/03/04
robo (sebring1970)
10:09:09 06/03/04
funny thing about this, sears and some other shops have
Halo Z
10:41:57 06/03/04
local NTB did mine for $79 with a year of "re-dos"
Guapo
10:58:22 06/03/04
What specs did you specify? I'm going to have a race
boileralum
11:05:11 06/03/04
that is awesome, but I'm not sure it would be easy to
robo (sebring1970)
13:02:52 06/03/04
OMG, i about dies when i called for alignment... -
SuparexTT
16:56:55 06/03/04
Called a shop the local Porsche guy sends his customers to..
SuparexTT
17:02:57 06/03/04
I don't think the four wheel part is that big of a deal.
robo (sebring1970)
06:38:35 06/04/04
Poly bushings can create bind if installed incorrectly. (n/m)
Taks
17:02:52 06/03/04
how can you "incorrectly" install a poly bushing? (n/m)
robo (sebring1970)
06:35:19 06/04/04
