TwinTurbo.NET: Nissan 300ZX forum - Re: massive engine failure
Subject Re: massive engine failure
Posted by Nukez on May 24, 2004 at 8:32 AM
  This message has been viewed 53 times.
In Reply To massive engine failure posted by fourZero on May 23, 2004 at 06:52 PM
Message Well,
Obviously if someone had an auto its not going to lock up.
This is not Z specific but
Alot of time if you really grenade the engine the rod comes through the skirt and falls into the pan or else comes right out the side of the block, the engine can still turn as the thing bangs around in the pan. If something got caught locking up the reciprocating assembly then it should lock one or both wheels. Since you said it was leaking at your turbo,
Perhaps your rotor disintgrated and some debris went down your intake and got wedged somehow. Just a WAG, most times
chunks down the intake wont lock it up either but I would think it would be possible at least. If you could get a boroscope somewhere you could look through the spark plug holes and see what the cylinders look like good luck
1991 2+2
1993 convertible
